Its scientificly proven that there is no way to manage sata cables unless you single sleeve them
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/542346-cable-help/#findComment-7177616
2 minutes ago, Flowey said:
For real do I'm guessing they were sleeved that way for servers who uses a lot of devices?
Nah just to be as space efficient as it gets, there are a lot of People that use more than 1 HDDs
https://linustechtips.com/topic/542346-cable-help/#findComment-7177645
Exactly. I have four 3.5" drives, and one 2.5" that I connect all together with a cable like this. Its very space efficient, and if you use all the connectors, then cable management takes care of itself.
Don't do drugs. Do hugs!
https://linustechtips.com/topic/542346-cable-help/#findComment-7177769
cable tie it to something in your case, thats what i do with all my stupid cables like that
Builds:
https://linustechtips.com/topic/542346-cable-help/#findComment-7177774
