Best Closed-Loop CPU Kit?
Go to solution Solved by Enderman,
2 minutes ago, FunkieFalcon said:
Well I will consider that If it really is worth it. But, what about the Corsair H110i GTX vs Kraken X61?
they perform the same
pick whichever looks best in your PC :)
what's your budget ??
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173442
I've always been partial to NZXT'S kraken x61
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173444
Just now, FunkieFalcon said:
No budget, just looking for performance.
i suggest an NH-D15, it's an air cooler but mops the floor with most liquid cooler even the H110, i should know i have one on my OCed i5 to 4Ghz maxing out at 75°C
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173471
That's actually really hot for that OC. I had my 4670k at 4.6GHz and it never broke 60C even during stress tests using an NH-D14.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173485
I've been spoiled by the simplistic design and size of water cooling kits. Air coolers are way to bulky for me and my case.
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173489
H110iGTX / kraken X61
OR
if you have a ton of money, the EK predator 360
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173491
i got on a silent profile ;)
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173496
Definitely EK predator 360, but the H110iGTX's are great.
Also, Kraken X61, although I've never used this cooler before, but Ive heard its really good.
Welcome to LTT! Feel free to PM me if you just wanna chat, I love conversation!
If you ever have any audio questions, wether it's software, hardware, or production and theory, feel free to ask me. Odds are I can help you, or get you help.
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173504
Never heard of the predator 360. How well does it perform?
better than all other AIOs on the market
its extremely expensive because it actually uses custom loop parts, so its basically just a prebuilt custom loop
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173538
What is the cost?
like $300 IIRC
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173544
https://linustechtips.com/topic/541904-best-closed-loop-cpu-kit/#findComment-7173572
