asus maximus viii extreme/assembly
NVIDIA geforce gtx 980 ti
Vengeance LPX 16GB (4x4GB) DDR4 DRAM 2666MHz C16 Memory Kit (CMK16GX4M4A2666C16)
Intel Core i7-6700K
intel ssd 750 series 400gb
WD 2tb internal hard drive black
cooler master MasterAir Maker 8
Silent Pro M2 850W
Arctic Cooling MX-4 4g Thermal Compound
BitFenix Spectre PRO LED green (1-140mm/3-120mm)
I am building this pc for gaming, software devellopement and vr. Any tips or advice?
https://linustechtips.com/topic/541900-help-on-building-my-pc/
what's your budget and location ?? and welcome to the forum ;)
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173413
@LawrenceBarnes2013 my budget is around 3000$ to 3500$ (I have some moving room so I can go up to 4000$ if worth it). It's my first pc build so help will be appreciated.
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173460
so i suppose the US or Canada ??
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173479
3 minutes ago, LawrenceBarnes2013 said:
so i suggest the US or Canada ??
First the location doesn't matter to me I can have everything shipped and it's fine. Second I thank u for your advice but I want something more powerful and I insist on silence (one of the reasons why I got the silent power supply). Also I can't decide on an X99 series or a ROG for my asus motherboard.
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173527
alright let me put together a build for ya
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173540
but keep in mind importing taxes
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.75 @ Amazon)
Motherboard: Asus SABERTOOTH X99 ATX LGA2011-3 Motherboard  ($308.99 @ SuperBiiz)
Memory: Corsair Dominator Platinum 64GB (8 x 8GB) DDR4-2400 Memory  ($514.36 @ Amazon)
Storage: Samsung 950 PRO 256GB M.2-2280 Solid State Drive  ($181.99 @ Best Buy)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($289.99 @ Amazon)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card (2-Way SLI)  ($748.99 @ SuperBiiz)
Case: Fractal Design Define R5 (Black) ATX Mid Tower Case  ($89.99 @ NCIX US)
Power Supply: SeaSonic X Series 1050W 80+ Gold Certified Fully-Modular ATX Power Supply  ($169.99 @ Amazon)
Total: $3808.02
Generated by PCPartPicker 2016-02-05 18:48 EST-0500
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173575
or this :
CPU: Intel Core i7-5960X 3.0GHz 8-Core Processor  ($999.99 @ SuperBiiz)
Memory: A-Data XPG Z1 32GB (4 x 8GB) DDR4-2400 Memory  ($179.99 @ Amazon)
Total: $3808.66
Generated by PCPartPicker 2016-02-05 18:45 EST-0500
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173597
Memory: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4-2400 Memory  ($499.99 @ Newegg)
Total: $3793.65
Generated by PCPartPicker 2016-02-05 18:42 EST-0500
Thx for the help ;)
https://linustechtips.com/topic/541900-help-on-building-my-pc/#findComment-7173609
