8 minutes ago, The_Dillster said:
Working on my friends laptop but for some strange reason the wireless icon in the bottom right of the screen takes at least 4-5 minutes to load in, any idea what's going on here??
Thanks in advance :)
Reinstalling windows is generally the fastest solution to problems with windows.
Just now, The_Dillster said:
Alas, this isn't an option for this either. Thanks fot the comment though! :)
Should keep storage on 2 partitions, a small one for windows in case reinstalling is needed, and long term storage on the secondary one so data isn't lost.
Also does it still have the charms/widgets if you go to the top right of the screen with the mouse or swipe in from the right? because wireless should be there as well.
Ok, I know 3 WiFi issues in win 10:
1) Upgrade Issues, fixed by this: LINK
2) Metro UI bugs with apps, fixed by this: LINK
3) Simple Icon add to Task Bar, fixed by this: LINK
Hope you find what you are looking for.
Also, 4) a drivers issues, fixed by this: make sure you have the manufacture one not windows 10 ones!
Thanks for those awesome posts! 3) was the closest one but that's where the problems seems to be. after i open the settings> Turn system icons on or off the network icon is off but unable to be turned on? come on windows...
