So I have an old PC with Athlon 2500+ XP with 768MB ram and FX 5200 Ultra... :D Since I dont have much money now Im kinda want it to be something like a media PC... I remember I was able to run 720p cartoon on it with ubuntu but I seem not to be able to do that again... So what are your suggestions for a light OS and light video player?
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/54134-light-os-for-old-pc/
ChromeOS Cherry or Windows XP.
If you've never heard of ChromeOS;
CPU: Ryzen 5 3600 @ Stock, CPU cooler: Dark Rock 4, Motherboard: MSI B450M PRO-M2 MAX, RAM: 2x8GB Crucial Ballistix DDR4 @ 3000Mhz, GPU: EVGA GTX 1080 ACX 3.0, SSD: Crucial P1 1TB M.2 + 2x120GB SSDs, Case: Corsair 110R, PSU: Corsair TX650M, OS: Windows 10 64-bit.
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-726521
Which Ubuntu have you tried? 10.04 and 12.04 32bit should run well, no? [13.04 is horrible don't try that one :D]
Tried 12.04... Hmm, found something called puppy linux, its only 165mb....
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-726528
I've been using 13.04 and it's faster on my laptop than 12.04. The CPU that my laptop is using is the old Intel Pentium Dual Core. Laptop is 5 years old.
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-736041
Had really big problems with 13.04, starting by Xorg not accepting my 3850. And so on and so forth and, nah. Fuck 13.04 and fuck amazon integration. ^^
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-736414
You can remove that.
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-736417
A Linux distro such as Mint might work well.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-767751
I would go for Windows XP as your best bet. Still the bet OS for me along with Windows 7. It's simple and light, like it was designed to work with PCs your generation anyways. If not, you can also try running Vista Home Basic. I have an old tired Acer travelmate with similar specs and it runs flawlessly with either Vista Home Basic or XP (Home or Pro).
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-775641
Windows Vista, make sure you don't install the service packs. That computer will run like it has never run before.
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-795733
trolling much?
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-795775
OP for the spec you listed XP is probably your best bet but you could probably get 7 or 8 to run on it. I dont know if you would see any real benefit with system that old if you choose to do that.
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-795780
Windows ME should work fine with that hardware. It's a good solid OS
FX-6300 @ 4.1 MHz; Cooler Master Hyper 212 Evo; XFX Radeon 7870 Core Edition; Arock 970 Extreme 3; Corsair CX600; Corsair Vengeance Blue 8GB(2x4GB) DDR3 @1600MHz; Seagate Barracuda 1TB; Zalman Z9 Case
Asus U43F-BBA7; i5-460M @ 2.53GHz; Crucial 8GB(2x4GB) @1333MHz; Intel 520 120GB SSD
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-795807
Linus Mint is a good start, or Xubuntu. Ubuntu is not lightweight out of the box.
Slighly more lightweight and ghetto, go for #! Crunchbang/Archbang.
https://linustechtips.com/topic/54134-light-os-for-old-pc/#findComment-796807
