What about using your BIOS?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/541332-cpu-fan-speed/#findComment-7167610
4 minutes ago, dragoncurt said:
What is the best program to change CPU fan speed as in some PC games my i5-6600k is going around 60c and sometimes higher. Thanks
Most motherboard manufacturers provide software (ASRock A-Tuning, ASUS Fan Xpert, etc.)
i like linux
https://linustechtips.com/topic/541332-cpu-fan-speed/#findComment-7167639
This is how you usually do it. You can set up a a curve so as temp goes up the fan speed does too.
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/541332-cpu-fan-speed/#findComment-7167644
Id rather do BIOS than software as some can be crappy. Especially Command Center from MSI.
https://linustechtips.com/topic/541332-cpu-fan-speed/#findComment-7167655
You can usually control fans connected to your motherboard through your bios settings.
https://linustechtips.com/topic/541332-cpu-fan-speed/#findComment-7177699
