Whatever you think looks best.
What is your color scheme/coolant color/other parts of loop?
https://linustechtips.com/topic/541309-cpu-liquid-cooling-block/#findComment-7167415
coloured fluid? yes?
get clear
https://linustechtips.com/topic/541309-cpu-liquid-cooling-block/#findComment-7167416
4 minutes ago, Afro_Lamb said:
I might dye the liquid blue and its hat gonna be a CPU loop ( possibly with GPU later)
Depends. I got a nice blue theme going on without seeing the liquid. It depends on what kind of look you are going for. Mine is more subdued.
PICS:
https://linustechtips.com/topic/541309-cpu-liquid-cooling-block/#findComment-7167452
Now that I'm using Aurora, I really wish I had a clear block, mine is clear on the sides but that doesn't do much good.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/541309-cpu-liquid-cooling-block/#findComment-7169974
