Hello,
I just received a new fangled raspberry pi with a SD card with NOOBS on it. This means I have the option of choosing operating systems, and me being bad at this went here for help. I would like to know if i should go for the traditional raspian or archlinux, or if there is something better. What should I  go with?
https://linustechtips.com/topic/540939-raspberry-pi-os-questions/
Depends what you want to do, and which os you prefer
There is no right answer
i suggest raspbian, it contains all you need to do what you want on the pi, as well as being the "official" os for it.
that said, theres some "roms" for specific purposes like retropie that may work better for you.
Honestly I think I'm going to go with archlinux because raspian looks really shitty. I am also not doing that much on the OS other than small games like undertale and internet things
raspbian is the best looking you'll be able to go on the pi, its not a powerful platform.
that said, it comes with lxde by default, which is quite customizable in the looks department without much extra overhead.
Doesn't really matter what it looks like, as long as it gets the job done. Especially on a device like this that doesn't have the ample CPU/GPU horsepower to support fancy GUI's.
I bought a Pi v2B not too long ago and went with raspbian (at least for now and to learn more about the platform first). It looks decent enough and works fairly well. I suggest installing the chromium browser as the default one in raspbian is horrible. lol. Just don't open more than a few tabs at once. 1GB of ram isn't much. ;)
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
Ubuntu Mate looks real good on Pi, and runs about as well as Raspian.
Also, Berryboot > Noobs.  You get a wider range of OS options; Kali, Ubuntu, Kodi, etc
Raspbian is the best choice if you don't have some really specific purpose in mind that another distro exists to do.  E.g.: if you want to use it as a home theatre system, use XBMC.  If you want to do a lot of retro gaming and have a really sweet emulator setup, use PiPlay or something like that.  If you want a general-purpose OS, Raspbian is the best bet, since it's designed by the Raspberry Pi people for the specific hardware, is very well-supported, runs very well (considering the inherent hardware limitations), and has a lot of software available.  Some of the other distros like Arch aren't always as stable on the Pi, and can be lacking in support (I don't know about Arch specifically--just using it as an example).
  • 2 weeks later...
HA! Good luck configuring Arch in under 4 hours. I would personally use raspian, as it can take full advantage of your Rasperry Pi.
