Hi guys....I'm trying to decide what Case Fans to buy for my rig when i start buying all the parts. Are the Stock Fans great already? ..been searching and searching case fans on newegg and etc...but it is hard to find the most reliable of them all :(
I'm planning to  overclock the cpu and gpu so i'll probably need a top of the line case fans when things go up a notch when i overclock it
Here is my build (a Revised and Improved version now from my previous post) (Final Parts!!) just need feedback on the case fans
is it good already? need options :(
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($339.99 @ Amazon)
CPU Cooler:  NZXT Kraken X60 98.3 CFM Liquid CPU Cooler  ($109.99 @ Newegg)
Motherboard:  Asus Maximus VI Extreme ATX LGA1150 Motherboard  ($399.99 @ Amazon)
Memory:  Corsair Dominator Platinum 16GB (4 x 4GB) DDR3-2133 Memory  ($261.00 @ Newegg)
Storage:  Samsung 840 Pro Series 512GB 2.5" Solid State Disk  ($444.99 @ Amazon)
Storage:  Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive  ($84.99 @ Amazon)
Video Card:  Galaxy GeForce GTX 780 3GB Video Card  ($689.99 @ Amazon)
Wireless Network Adapter:  Rosewill RNX-N180UBE 802.11b/g/n USB 2.0 Wi-Fi Adapter  ($17.85 @ Amazon)
Case:  Fractal Design Define XL R2 (Black Pearl) ATX Full Tower Case  ($143.58 @ Newegg)
Case Fan:  Noctua NF-F12 PWM 55.0 CFM 120mm  Fan  ($28.99 @ Newegg)
Power Supply:  Corsair Professional Gold 1200W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply  ($269.99 @ Amazon)
Optical Drive:  Asus BW-14D1XT Blu-Ray/DVD/CD Writer  ($94.98 @ Newegg)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($90.88 @ Amazon)
Monitor:  Asus PB278Q 27.0" Monitor  ($553.99 @ Amazon)
Total: $3618.17
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-09-07 06:52 EDT-0400)
;_;
https://linustechtips.com/topic/54075-case-fan-dillema/
you got 4 nf-f12s in there, it cant be bad. :P
just get some nf-a14, the ones that linus uses in his heatsink testing videos. Noctua=awesome.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725618
cool :D so in your opinion..do i go all nf-a14 and replace all stock fans and also the kraken stock fans or do i only replace the stoc case fans? :D
;_;
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725642
noctua fans are really good, however alot of people don't like the colour. I would say go for the nf-f12 for your radiator, and then go for a nh-s12 for the case.
Here is the link to noctuas website.http://www.noctua.at/main.php?show=which_fan_is_right_for_me&lng=en
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725649
arent those corsair fans good?
noctuas are much better
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725653
thanks sir :D the NF-S12A has a 5 star ranked on that page..is that a better option too?
;_;
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725664
I dont think any case fan is any good aslong it is not made by a descrete fan manufacteur.
put 2 nf-a14s as exhaust on your X60, and fill the rest of your case with NF-F12 as intakes, just connects them all directly to your psu with some 7V adapters. Quiet, and powerful.
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725672
if you read the page, it says that the nh-f12 is good for radiator and heatsinks, the nf-s12 is good for case ventilasation and quietness, but not for heatsinks, and the nf-p12 is an all rounder.
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725678
if you read noctuas page, it says the nh-f12 is not good for a case fan, it would be better going with a nf-s12.
So the kraken x60 is 2  140mm fans? in that case 2 140mm fans then.
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725685
hmmm....but will that affect me though especially when overclocking and etc? since i'll probably overclock the cpu and the gpu from the start. sorry i'm a total newbie in these kinda stuff. .
what i'm asking is is it really a good idea putting all the case fans and connect it directly to the psu?
how about connecting most into the mobo and just put the leftovers to the psu?
;_;
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-725702
If you really want to monitor and controll all your fans, you can plug your mobo full of fans, but keep in mind, you will have to run all the wires to the headers, which will make your system look much less tidy. Also when running a high end watercooling system like a X60, the performance gain from beeing able to run the fans at full speed is very little, but the difference in noise is quite big.
For a beginner, I will always recommned leaving your fans running at a fixed rpm where there's a nice balance between performance and noise.
If you want to oc your cpu this also helps to make your coolers potential more consistent and easier to predict what heat load it can handle.
https://linustechtips.com/topic/54075-case-fan-dillema/#findComment-726086
