Add at least a 1TB hard drive, and change the case to the NZXT Noctis 450.  What are you using this computer for?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/540138-help-with-my-build/#findComment-7154567
go with the Noctua NH D15 cooler. it will be quiter with about the same performance maybe even a little better.
I believe johnnyguru gave the hx860i a better review than the PSU that you currently have selected. And unless you like the looks of that case there are cheaper better quality towers that are alot cheaper. Fractal for example. they should really start paying me for advertising their products, but seriously they look amazing, made with metal instead of plastic and are affordable. plus they look amazing
https://linustechtips.com/topic/540138-help-with-my-build/#findComment-7154600
looks great to me :) good parts selection
a large HDD for mass storage might come in handy if you have a lot of videos or games
https://linustechtips.com/topic/540138-help-with-my-build/#findComment-7154641
mainly for gaming/streaming
5 hours ago, ChronicGenocide said:
The power supply is a bit overkill, however everything else looks good. Maybe want to invest in a larger SSD.
im planing to buy another 980ti in the future
https://linustechtips.com/topic/540138-help-with-my-build/#findComment-7155607
http://pcpartpicker.com/p/tn9YnQ
here, try this build only $2000+
a much better build imho
CPU i7-6700k Motherboard MSI Z170A GAMING M5 RAM KINGSTON HYPERX FURY 2X4GB GPU ZOTAC GEFORCE GTX970 AMP! EXTREME CORE EDITION Case COUGAR ATX Storage WESTERN DIGITAL BLUE 1TB PSU CORSAIR RM650X Display(s) AOC G2460PQU 24" Cooling COOLER MASTER HYPER 103 CPU COOLER Keyboard CORSAIR STRAFE RGB Mouse CORSAIR M65 RGB Sound MICROLAB FC360/RAZER KRAKEN 7.1 CHROMA/AUDIO TECHNICA M50X Operating System WINDOWS 7 ULTIMATE
https://linustechtips.com/topic/540138-help-with-my-build/#findComment-7155690
