Will this script work? (Command Prompt)
Hi Everyone,
Just wondering if someone could let me know if this script will work or not.
powershell -ExecutionPolicy ByPass -File 2.ps1
The "2.ps1" is the name of my power shell script, using the above code I want to execute the power shell script from within command prompt.
The reason for behind this, is that I need to run a power shell script along with multiple other command prompt commands. The "ByPass" is to, well simply bypass the power shell execution policy.(Which is set to restricted by default)
I could of course manually restrict and unrestricted the power shell execution policy, however I plan to run this on more than 100+ machines. Which means the more automation the better. xD
Many thanks in advance.
Connor Freebairn - ConnorFreebairn@newman.cumbria.sch.uk
IT Technician & Certified computer geek.
https://linustechtips.com/topic/539601-will-this-script-work-command-prompt/
