Hey guys I am planning my future build and want to make it an MITX build.
I live in Canada so I prefer everything for be from newegg.ca or Tigerdirect.ca, and ekwb for Watercooling.
I want to watercool.
My budget is $750 but I can bumb up to $1000.
I would like a custom loop and want the case to be a bitfenix prodigy.
A cherry mx Blue Keyboard would be nice but not needed in the $750
No monitor
No mouse
No Speakers
.etc
EDIT: I have the RAM, don't worry about that, and also, AM3+ would be preferred but I don't know if there are any MITX AM3+ Mobos.
(I know that I posted another build a few days ago but I have changed my mind)
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/53878-750-m-itx-build-help/
Custom loop for that budget, forget it. It quickly adds up. What you can do is start basic with an air cooler, then save some money for the custom loop. Just make sure you'll save some room in the case for it, but it should be fine, it's been done many times before.
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723326
Would it be possible to add an external radiator to a h100i?
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723337
What I'd recommend in your position is buy a cheap aircooler while you save up for your custom loop. Custom loops with a CPU and GPU block can easily cost 300$ + most mini ITX don't have windows anyways so there's nothing to show off. You're best off getting the best hardware now and then  you can add the other things later.
Case: 650D CPU: i5 4670K GPU: GTX 770 Gaming @1306MHz Motherboard: MAXIMUS VI Hero PSU: AX760 CPU Cooler: H100i RAM: 8GB Vengeance Pro @1866MHz Storage: 840 250GB SSD / 2TB Seagate Barracuda 7200.14
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723338
I was going to mod a window into the case. forgot to add that to the OP
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723344
No monitor
No mouse
No Speakers
.etc
No such thing as AM3 ITX. If you want to do a loop, your only options are to buy a kit from someone like XSPC or use a T-line to cut costs. You will only be able to WC your CPU, this would bring your total build budget down to 850 assuming 1k.
@megadarkwood here is a basic config http://ca.pcpartpicker.com/p/1AHci
Error: 410
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723349
Bitfenix does sell windows for the prodigy  ;)
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723354
I am going to put a larger window into the right side to see more or everything.
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723368
What is there to see? The right side is dominated by the graphics card and nothing else can really be seen.
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723372
The GPU is on the left side, the right side is the one with the front OI
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723381
Thanks, I will keep it in mind
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723383
Oh ok I'm thinking from the rear of the case.
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723388
You could go an APU build, they are m itx.
Watercooled APU.
Haha, that's be fun.
https://linustechtips.com/topic/53878-750-m-itx-build-help/#findComment-723509
