I need to know whether all of these parts are compatible with each other. Thanks:)
I can only get the parts from MSY because it is the only store where I can pick up in store. I wish there was pccasegear in Adelaide but there isn't. There are reasons to why I cant order online.
Budget is below 2k Aussie. :)
CPU: Intel Core i5-6600K 3.5GHz 6MB LGA1151 Skylake Boxed CPU - $361
Motherboard: Asus ROG MAXIMUS VIII HERO Intel Z170 S1151 4xDDR4/3xPCIEx16/HDMI/DP/USB3.1/ATX Motherboard - $369
Memory: Kingston HyperX FURY HX424C15FBK2/16 16GB Kit (8Gx2) DDR4 2400 Desktop RAM - $149
Storage: Samsung 850 EVO MZ-75E250BW 250G SATAIII SSD Solid State Drive - $129
Storage: WD 3.5" Blue 1TB WD10EZEX SATA3 64M 7200rpm HDD - $69
Video Card: Gigabyte N970WF3OC-4GD 4G GTX 970 WINDFORCE OC PCI-E VGA Card - $479
LG DVD RW - SATA - $18
Netgear A6100-10000S AC600 Dual Band WiFi USB Mini Adapter - $39
Antec TRUEQUIET120-RD "TRUEQUIET" 120mm Red LED Rubber Case Fan with 2 Speed Switch - $15 (Front Intake)
Partlist PL-FAN12CM 12cm Case Cooling Fan - $3 (Top) (Exhaust) x2 - $6.00
Coolermaster Xtraflo 120mm Case Fan R4-XFBL-22PR-R1 - $12 (Rear) (Intake)
Case:  Corsair CCSPEC-01 Carbide SPEC-01 Black USB3.0 Mid Tower Case without PSU - $79
Power Supply: Antec HCG-520M 520W High Current Gamer 'Modular' Gaming PSU - $104
$1725
https://linustechtips.com/topic/538601-will-my-build-be-compatible/
$1725
make this into a www.pcpartpicker.com link
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Just now, Tornation said:
Yes it will be! The psu linked has 2x 6+2 pin connectors. Your gpu requires a six and an eight pin connector from my quick research. Also it has 45 amps on it's 12 volt rails so that will be plenty.
Jut one problem>
Thanks but I can only buy my parts from msy and I cant oder online. Msy is the only store in adelaide. I wish pccasegear was in adelaide. Anyways will this be a better alternative:
Corsair CMPSU-600CXV3 600Watt 80Plus Bronze ATX Power Supply Unit
3 minutes ago, Meow_Cookies said:
Jut one problem>
Hmm... Corsair cx series are notorious for not having the best build quality... You might even want to step up to antec's true power series.
P.S. I don't actually live in AU so I'm getting used to navigating these sites :P
~ Luc Luc
4 minutes ago, Tornation said:
Antec HCG-620M 620W High Current Gamer 'Modular' Gaming PSU
I think this will be my best alternative valued at $124
Not quite as efficient but it will definetly get the job done. Just keep in mind it is a little noisier than the VERY FIRST psu you originally selected.  Also just to re-iterate the first psu you chose was fine, another was just recommended for upgrade-ability purposes.
~ Luc Luc
ok, thanks when i start upgrading i will change the psu.
