Sapphire 7950 = jet engine?
Go to solution Solved by BoomLiam,
How would I go about that? the only option I see in the Catalyst driver is to manually set the fans at a fixed percentage
Download MSI Afterburner, run a game, see what speeds your fans are running at (by turning on OSD (On screen display) and the temperature of the card. Adjust the fan speeds at each temperature as you see fit. This should fix your problem :)
I just assembled a system with a Sapphire HD7950 Dual-X
The card is freaking loud! Can anyone share any ideas to make it more quiet? Feeling pretty fucked right now...
More details: it is 'bearable' at idle, but once the fans ramp up past 40%, the system is just as loud as a hair blower. The problem is that it shoots over 40% almost instantly once you put any load on it...
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/
Set your own fan curves. Either that or buy an aftermarket cooler.
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721751
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721755
With MSI Afterburner.
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721760
Computer Specs (The Space Fridge):
CPU: Intel i5 3570k | Motherboard: MSI Z77A G45 | RAM: Kingston Hyper X Blu | SSD: OCZ Agility 3 (60GB) |
HDD: Seagate Barracuda (500GB) | GPU: MSI HD 7950 Fwin Frozr iii | PSU: Corsair CX600 | Case: NZXT Phantom 410 w/ NZXT Blue LED strip
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721761
Didn't know you could also set fan curves in afterburner. Will try now and report back
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721772
Sapphire has its own utility called Trixx but Afterburner is certainly more functional.
Case = Bitfenix Prodigy, Motherboard = P8Z77 - I Deluxe, CPU = 3570k @ 4.2GHz, RAM = 2x 8GB G-Skill Ripjaws, GPU = Sapphire 7950 Boost Edition, Storage = 256GB Samsung 840 Pro.
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721792
Thanks guys! card is whisper quiet now :)
what are the temps of you unit?
They were only about 65 degrees at gaming load. The problem was that the fans were running at nearly 50% at that point.
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721823
They were only about 65 degrees at gaming loud. The problem was that the fans were running at nearly 50% at that point.
well, i suggest you make an fan profile, wich gets up to 85 degrees, wich is acceptable for a GPU, but will be much quieter
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721829
You can also get sound dampening, but that is not possible with every case, if not, you can set up fan curves, but that might hurt your tempatures a little. If it's too much, buy a silent case like Define R4 or CM Centurion Silencio.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721845
A curve like this should help keep your card quiet:
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721865
Case is a Corsair 200R. Not really built for silence :P
Temps are not a big problem...
https://linustechtips.com/topic/53768-sapphire-7950-jet-engine/#findComment-721998
