Okay so I decided to try and make a build capable of playing Fallout 4 well and I have created this build.http://uk.pcpartpicker.com/p/dyRz23
I also decided to set myself a challenge and set a budget of £750 GBP and use only one supplier.
What do you think of the final build?
https://linustechtips.com/topic/537200-latest-plan-for-pc-build/
I would reccomend not going for AMD, they have bad performance even though they look like a best bank for the buck.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/537200-latest-plan-for-pc-build/#findComment-7124736
The PSU isnt that well regarded,
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
Try and go for a higher tier
| MOBO MSI Z97 Gaming 3 | CPU i7-4790K @ 4.7GHz | RAM G.Skill 16GB 2133MHz | SSD Kingston 240GB / HDD Seagate 3TB | GPU MSI Gaming GTX 970 |
| Cooling CM Nepton 240M | Display Philips BDM4065UC 40in 4K | Keyboard Corsair K70 Cherry Blue | Mouse Logitech G502 | Case Fractal Design Core 2500 |
PSU Rankings
https://linustechtips.com/topic/537200-latest-plan-for-pc-build/#findComment-7124760
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  (£155.99 @ Amazon UK)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£64.99 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£65.98 @ Amazon UK)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  (£168.77 @ Amazon UK)
Case: Thermaltake Versa H21 ATX Mid Tower Case  (£35.20 @ Amazon UK)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£44.17 @ Amazon UK)
Optical Drive: Samsung SH-224FB/RSMS DVD/CD Writer  (£11.79 @ Amazon UK)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£62.99 @ Amazon UK)
Monitor: BenQ GL2250HM 60Hz 21.5" Monitor  (£89.99 @ Amazon UK)
Keyboard: Zalman ZM-K400G Wired Gaming Keyboard  (£20.50 @ Amazon UK)
Total: £753.35
Generated by PCPartPicker 2016-01-29 18:38 GMT+0000
my work in progress
i5 6600k  //  16gb g.skill ddr4 3000  //  evga gtx 980
custom water loop
https://linustechtips.com/topic/537200-latest-plan-for-pc-build/#findComment-7124785
^ get that
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/537200-latest-plan-for-pc-build/#findComment-7124803
