144hz and 60hz Dual Monitor
Big Wang
Hello, I have a 144hz monitor which I use for my main display and a 60hz on the side, on the 60hz monitor im getting MAJOR screen tearing when I try to move something around or watch a 60fps youtube video. Im on windows 10
Does anybody know how to fix this? Thank you
Hello, I like apples.
I think Windows defaults refresh rates to the lowest maximum value. I could be wrong, though, but I can't get my 75Hz monitor to stay at 75Hz while I'm using a secondary, 60Hz display.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Intesting, on my geforce control pannel it says 144hz and never changed? Would this be display a false number or would it change?
I updated my drivers and its fixed. I'm so fucking stupid. Sorry for the useless thread! xD
You found and fixed the problem yourself, plus you bothered to look on forums and ask for help which is not stupid. Stupid would be if you kept using your monitor and ignored all the tearing, and sat there like an idiot thinking it's all good. :)
Ah thanks man.
