Good Power supply?
Go to solution Solved by WoodenMarker,
Thats a bad spu. It blows up.
No, it's not a bad psu. It's not the best unit but shouldn't have issues or blow out.
Your current Rosewill Arc is fine and your system uses ~400w at load--not 600w. Avoid psu calculators in the future and look at actual power draw benchmarks instead.
so, recently I built my first gaming PC you can see that here
http://linustechtips.com/main/topic/532082-good-value/
And within that build I bought a rosewill ARC 650W bronze Power supply.
After that post i realized i needed a new power supply (seriously check out the comments)
Anyways my Pc is using about 600W of power
http://outervision.com/b/DRPEPF
Finally i was wondering what PSU i should get? preferably low cost (like around or under $70 US)
post-260155-0-97706700-1453929485_thumb.
https://linustechtips.com/topic/535941-good-power-supply/
https://linustechtips.com/topic/535941-good-power-supply/#findComment-7109373
I'm not going to get too specific but EVGA's G2 and XFX XTR series are good PSUs. Just check out the versions that deliver the right amount of watts.
  • AMD Athlon X4 760K CPU   |   MSI FM2+ ATX A88X-G45 Motherboard   |   8GB 1600MHz RAM   |   MSI GTX 760 GPU (Reference)
  • Thermaltake Versa H22 Case   |   1TB Seagate, 0.5TB Hitachi (7200RPM)   |   ArcticRed+ 700WStock    |   Windows 8.1
https://linustechtips.com/topic/535941-good-power-supply/#findComment-7109386
https://linustechtips.com/topic/535941-good-power-supply/#findComment-7112513
