This is the smallest 4k display that i could found for a pc.
It's the Dell P2415Q, 23,8in
Just curious, is there any 4k pc display smaller than this? Repeat, for a PC...
I know about this one: 9.8in, 4K also... but for medical uses or something like that...
https://linustechtips.com/topic/534067-smallest-4k-display/
24" is the smallest mainstream 4K monitor you'll be able to find.
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086475
why
4k is pointless on screen sizes that small
if you can see the pixels on a 24" monitor then you're sitting way to close
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086479
why
I can see where the pixels are on my P2416D (1440p version of this one).
I sit just over 2 feet away.
5800X3D - RTX 4070 - 2K @ 165Hz
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086500
oh really then
so you can tell that this is clearly a square and not a dot?
without zooming in obviously...
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086543
well... i have a 1440p display also, i'm not that close to it but i can still "see" them, guess i have sharp eyes?
On smooth objects. (Like outlines of cars, boats, ect.) I see the stepping.
I understand the upgrade to 4K, but it is very expensive.
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086548
oh really then
I see where they are. Not the actual pixels. (Usually)
My windows button I can see the pixels. I can also see them on the search.
I also notice them when playing World of Warships on my boat.
In GTA the text and headlights allow me to see the pixels.
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086563
yeah thats not what i mean
by "see the pixels" i mean you look at a diagonal line and it looks jagged because you can see the flat sides of the pixels making a staircase look
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086590
for me is the same, in games you can see them a lot, unless you activate anti aliasing i think? or was something else? however this stepping can be reduced, but never hide completely...
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086594
It is very much reduced when going from 1080p to 1440p, but they are still there.
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086601
AA fixes the jagged lines that are diagonal to the pixels.
But you cannot get rid of them completely. So more pixels makes it much smoother.
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086619
The Windows 10 button iss just trash though, they should usse the old 8 one, its was much sharper
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086667
for example: my iphone 5 has 326 ppi, i know that you take your phone closer to you than a pc screen, but even with that high ppi i can still barely "see" the stepping... how many ppi we need to be satisfied??? :)
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086676
300 or so. My phone has ~450 and I can't see the pixels no matter how close I get.
https://linustechtips.com/topic/534067-smallest-4k-display/#findComment-7086694
