So I know how you build the PC outside the case to see if it posts and all the parts are working, I'm building a PC for a friend and I have all the parts expect a case, (The case is broke and they had to order a new one) I've already tested outside the case to make sure everything works and I was wondering if I can in the mean time install Windows on the hard using a flash drive on the "Test Bench" (building on motherboard box)? If so how should the parts be layed out? Thanks!
https://linustechtips.com/topic/534059-pc-build-question/
The motherboard should sit face up on the box, everything else doesn't really matter and can sit on the surface around the box. You can certainly install Windows in this state assuming your HDD is connected.
 Almost as cool as my temps
https://linustechtips.com/topic/534059-pc-build-question/#findComment-7086377
make sure that the motherboard has the ram and cpu and cooler installed. also make sure the hard drive is plugged in. the hard drive, motherboard and power supply should all sit on different pieces of cardboard without them touching each other. You dont want any short circuits now do you ;)
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/534059-pc-build-question/#findComment-7086382
hi have a question. just lost my hp mobo a few days ago replaced it with a gigabyte ga-b75m-d3h.  currently using a amd radeon hd 7570 and am wondering what I might be able to upgrade to for less than 200 bucks. using a 400w psu and an intel i7 2600 @ 3.4 GHz cheapie 1330 ram from Samsung 16gb. first time builder here as well, just want something to call my own. thanks for any and all help.
https://linustechtips.com/topic/534059-pc-build-question/#findComment-7087015
