Question about front I/O
Go to solution Solved by Minsekt,
I cant find a card reader with micro sd SD SDXC
sandisk offers them in bundle with their 64gb+ cards afaik
like this one here http://www.amazon.com/Lexar-High-Performance-MicroSDXC-version-LSDMI64GBBNL633R/dp/B00IF4OATU/ref=sr_1_9?s=pc&ie=UTF8&qid=1453582682&sr=1-9&keywords=micro+sdxc
or get this one http://www.amazon.com/dp/B00LHPEL66?psc=1
Hey,
I am thinking about buying this internal card reader
http://smile.amazon.com/NZXT-Aperture-Internal-5-25-Inch-AA-APMU3-B1/dp/B008KEPWMY/ref=sr_1_3?ie=UTF8&qid=1453578858&sr=8-3&keywords=internal+sd+card+reader
And i look at the connectors for the card reader, it is USB 3.0.
But i already use the USB 3.0 connector them for my case's USB 3.0
So what do I do, do i just have to buy a hub or something? or not use my case's USB 3.0?
I have The fractal design define R4
and a UD5H z97x
Cheers,
Michael
Case: Fractal Design Define R4   CPU: 4790K OVCK 4.7  CPU COOLER: H100iGTX (NOCTUA FANS) RAM: COSAIR VENGEANCE PRO (2x8) MOBO: GIGABYTE UD5H z97x  PSU: EVGA SUPERNOVA 750 WATT 80+ GOLD GRAPHICS CARD: GIGABYTE G1. GAMING WINDFORCE 970 4GB BOOT SSD: Crucial m550 M.2 256 GB HDD: SEAGATE BARRACUDA 2TB  2nd SSD:SAMGSUNG 500 GB 850 EVO
https://linustechtips.com/topic/533168-question-about-front-io/
You can use adapters that convert from USB 3.0 to USB 2.0. http://www.newegg.com/Product/Product.aspx?Item=N82E16812162025
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7075964
if your motherboard does not have 2 internal usb 3.0 connectors you have to choose what youre using. why not just buy a external card reader?
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7075965
well you can just leave the USB3 header for the card reader unplugged. If the card reader only has USB3 header to plug in i'd just use those instead of your case, or buy an adapter to usb2
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7075966
the internal USB3 connector is only for the two USB3 ports
the other card readers an stuff use the internal USB2 connector
you can use the card readers with only the USB2.0 header plugged in, and not the 3.0
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7075971
Yes, you can decide to not use the case front i/o, add more internal usb 3.0 headers, or get another card reader that doesn't use a usb 3.0 header.
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7075977
Would it hinder the performance?
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7075989
If you're using all of them at the same time, it might. But I don't think you'll notice it that much if it's actually there. If you want to use the reader, it's the sacrifice you'll have to make. Alternatively, you could purchase the adapter, connect your USB 3.0 ports to it and connect that to the motherboard, and then connect the reader to the USB 3.0 header.
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7076016
Yes, it would be limited to usb 2.0 speeds.
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7076027
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7076309
Fire Strike Score
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7076377
Thanks mate! :)
https://linustechtips.com/topic/533168-question-about-front-io/#findComment-7077393
