CX.....
Use both
https://linustechtips.com/topic/533042-r9-380-power-help/#findComment-7074147
You use 2 6 pin cables with out the "+ 2"
https://linustechtips.com/topic/533042-r9-380-power-help/#findComment-7074153
CX.....
Use both
This
This
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
https://linustechtips.com/topic/533042-r9-380-power-help/#findComment-7074167
BOOM???
CX are crap and only suited for Offices PCs with NO dGPUs
https://linustechtips.com/topic/533042-r9-380-power-help/#findComment-7074176
Yeah, you might not be too happen if your current set up. However, I have heard cases where people have used CX psus for gaming rigs for a couple of years just fine, so pray that you´ll be one of them.
https://linustechtips.com/topic/533042-r9-380-power-help/#findComment-7074192
#PrayforCX
https://linustechtips.com/topic/533042-r9-380-power-help/#findComment-7074199
4790 and R9 290 for two years yyeaahh BWWWOOOOIII
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/533042-r9-380-power-help/#findComment-7074203
