Your best option when on a tight budget is used, unfortunately that is also more of a pain than simply buying new due to the uncertainty but worth it with what I assume is a shoestring budget like yours.
Edit: 140 bucks is almost enough to buy an new R9 280, why were you looking at a 610? you could find a 290 used for around that or a 280x as for new idk a 950 is about it that I can see
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/532498-need-help-for-gpu/#findComment-7068043
At this budget you're gonna want to go AMD.
  • AMD Athlon X4 760K CPU   |   MSI FM2+ ATX A88X-G45 Motherboard   |   8GB 1600MHz RAM   |   MSI GTX 760 GPU (Reference)
  • Thermaltake Versa H22 Case   |   1TB Seagate, 0.5TB Hitachi (7200RPM)   |   ArcticRed+ 700WStock    |   Windows 8.1
https://linustechtips.com/topic/532498-need-help-for-gpu/#findComment-7068092
