Posted January 22, 2016 So my grandparents need a computer, so I can either sell them mine (Without the GPU) or build them a new one. I figured that I may be able to just make a new build without a GPU for myself. My first thought for this was an Athlon X4 760K. How does this compare to an i3 4130 in gaming? All I play is Minecraft, and I'd like to record it. Currently I get 90fps recording (about 300-400 when I'm not). I was wondering if I'd be able to get more fps recording with the Athlon or another CPU around that price point? The Athlon is a quad core and is clocked a little higher, so maybe it'll do better recording? I'm not sure. But basically I'd like to try getting better fps while recording. My budget with an OS is about $400, but I already have an R9 270. Or what about an Athlon X4 860K?? | CPU: Intel Core i3 4130 | GPU: PowerColor R9 270 | Motherboard: Asrock H81M-HDS | RAM: Kingston HyperX Fury 4GB | |HDD: Western Digital 1TB | Case: NZXT Source 210 | PSU: Corsair CX430W | | Mic: Blue Snowball iCE | Mouse: Corsair K65 RGB | Keyboard: Razer Blackwidow Chroma | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2016 Get the 860k. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2016 i3 will do better in games and recording if you use Intel Quick Sync. Best Bench Runs & 24/7 Rig Spoiler Best Bench Runs i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T Spoiler 24/7 Rig & Clocks i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2016 Oute of the 2,the i3 by a slight margin.BUT!If you are willing to get a really decent bang for buck quadcore,get the X4 860K. Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2016 Author i3 will do better in games and recording if you use Intel Quick Sync. What is Intel Quick Sync? | CPU: Intel Core i3 4130 | GPU: PowerColor R9 270 | Motherboard: Asrock H81M-HDS | RAM: Kingston HyperX Fury 4GB | |HDD: Western Digital 1TB | Case: NZXT Source 210 | PSU: Corsair CX430W | | Mic: Blue Snowball iCE | Mouse: Corsair K65 RGB | Keyboard: Razer Blackwidow Chroma | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2016 What is Intel Quick Sync? It is where it uses the iGPU (Intel HD) to do all the recording for you so you take no performance hit in game. Best Bench Runs & 24/7 Rig Spoiler Best Bench Runs i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T Spoiler 24/7 Rig & Clocks i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2016 Author It is where it uses the iGPU (Intel HD) to do all the recording for you so you take no performance hit in game. Wow, that sounds cool. I'm gonna take a look at that, thanks! | CPU: Intel Core i3 4130 | GPU: PowerColor R9 270 | Motherboard: Asrock H81M-HDS | RAM: Kingston HyperX Fury 4GB | |HDD: Western Digital 1TB | Case: NZXT Source 210 | PSU: Corsair CX430W | | Mic: Blue Snowball iCE | Mouse: Corsair K65 RGB | Keyboard: Razer Blackwidow Chroma | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
