I was on reddit and ended up at this site
http://www.npr.org/sections/therecord/2015/06/02/411473508/how-well-can-you-hear-audio-quality
It's a test to see if you can tell the difference between uncompressed WAV, 320kbps.mp3, and 128kbps.mp3 samples.
I used an okay pare of headphones hooked up to my laptop and got 3 of the 6 WAV samples although I'd say 2 were guesses.
How well did you guys do?
My posts are in a constant state of editing :)
CPU: i7-4790k @ 4.7Ghz MOBO: ASUS ROG Maximums VII Hero  GPU: Asus GTX 780ti Directcu ii SLI RAM: 16GB Corsair Vengeance PSU: Corsair AX860 Case: Corsair 450D Storage: Samsung 840 EVO 250 GB, WD Black 1TB Cooling: Corsair H100i with Noctua fans Monitor: ASUS ROG Swift
laptop
Some ASUS model. Has a GT 550M, i7-2630QM, 4GB or ram and a WD Black SSD/HDD drive. MacBook Pro 13" base model
Apple stuff from over the years
iPhone 5 64GB, iPad air 128GB, iPod Touch 32GB 3rd Gen and an iPod nano 4GB 3rd Gen. Both the touch and nano are working perfectly as far as I can tell :)
https://linustechtips.com/topic/532153-found-an-interesting-audio-test/
someone literately posted this earlier today so ill just give you my results from them... i choose the 128 once and mainly choose the 320 and couldnt get the uncompressed more than once. they were to close. 320 and uncompressed that is
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
Found out 4, although i can tell the difference b/w 4/6,Seriously couldn't not find the difference b/w Mozart: Piano Concerto  and NEIL YOUNG's ‘There’s A World’ and selected 320, i'm not a audiophile, but i know enough and an avid soundtrack listener
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
