Hello all!
I had a crazy idea com across my mind. I have an old G100s lying around, doing nothing, so I had the bright idea to 3D print a new, custom case for the censor and PCB. Maybe make it a little nice to hold. Stuff like that.
Is this a good idea?
Bad Idea?
Really cool idea?
Any other suggestions?
Thanks in advance!
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/
I've wanted to do this, following, @TheGhzGuy follow your own topics
Join the Appleitionist cause! See spoiler below for answers to common questions that shouldn't be common!
Q: Do I have a virus?!
A: If you didn't click a sketchy email, haven't left your computer physically open to attack, haven't downloaded anything sketchy/free, know that your software hasn't been exploited in a new hack, then the answer is: probably not.
Q: What email/VPN should I use?
A: Proton mail and VPN are the best for email and VPNs respectively. (They're free in a good way)
Q: How can I stay anonymous on the (deep/dark) webzz???....
A: By learning how to de-anonymize everyone else; if you can do that, then you know what to do for yourself.
Q: What Linux distro is best for x y z?
A: Lubuntu for things with little processing power, Ubuntu for normal PCs, and if you need to do anything else then it's best if you do the research yourself.
Q: Why is my Linux giving me x y z error?
A: Have you not googled it? Are you sure StackOverflow doesn't have an answer? Does the error tell you what's wrong? If the answer is no to all of those, message me.
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7055066
Hello all!
Bad Idea?
Really cool idea?
Thanks in advance!
Do it, it sounds cool.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7055079
Why not, if you can 3D model, have access to a 3D printer, and don't need the mice anymore.
I like it. when you have something drawn up, show it to us in the modding subforum!
I have a triple extruder 3D printer at school, so that works. I have access to AutoDesk. And I really don't need the mouse lol.
Alright, I'll put it there when I get everything together and working ^^ (I have to fix the 3D printer because for some reason it doesn't work)
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7055139
This is actually a really cool idea I see people asking for things for their mice that just aren't made by anyone like a more grippy material for the top of the mouse and things like that. I think 3d printing those things is a great idea
Just because something doesn’t do what you planned it to do doesn’t mean it’s useless. – Thomas Edison
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7062151
A friend of mine suggested that I have ventilation holes so your palms don't sweat.  I don't really know how to get the grippy material on a 3D printed mouse though. That part confuses me.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7065683
yeh, i'm not really sure how a grippy material like rubber would work in this scenario either, just tossing out ideas :P
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7065807
I think it's polycarbonate
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7066083
Don't know how I'd feel about that on a mouse considering if you do sweat, it would go down.
MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400
EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+
Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7066435
Bad Idea?
Really cool idea?
Im no expert on 3d printing but i think you are severely limited design wise in comparison to injection molding, also you need the capability to print with ABS.
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7066611
Yeah, there are some design issues, but I think I can get around it. I'm going to be one of the three 3D printers at my school can use ABS plastic
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7066673
Maybe if you could add some very fine grooves they'd improve grip and ventilation
https://linustechtips.com/topic/531684-custom-mouse-shell-thing/#findComment-7067178
