Fan setup for H440
Go to solution Solved by TheJaakko10,
I'll just go with the stock ones then. Thanks. c:
So. I am currently trying to decide on how to configure the fan setup in the NZXT H440
I will put a Corsair H110i in the top of the case (which I will configure to push air out of the case),
but should I replace the 3 stock fans in the front with Corsair SP120s/AF120s?
(I am going on a semi tight budget here so I am trying to find out if the "better" fans are worth the extra money.)
Also going to remove the HDD bay, just for airflows sake.
Any other suggestions on how I should do things?
https://linustechtips.com/topic/529778-fan-setup-for-h440/
im using nf-f12s up front and honestly...I cant say I noticed a diffrence
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/529778-fan-setup-for-h440/#findComment-7028971
corsair fans are crap for the money
get some beqiet silent wings or noctua fans or fractal design r3 fans
the r3 will be cheapest
https://linustechtips.com/topic/529778-fan-setup-for-h440/#findComment-7028992
I havent heard much about the R3 so theyre better than the silent wings and noctuas?
https://linustechtips.com/topic/529778-fan-setup-for-h440/#findComment-7029035
no, but they are quiet and they are cheap
https://linustechtips.com/topic/529778-fan-setup-for-h440/#findComment-7029054
