Hi,
I have a pc with 3mbps connection and my friend has with 1mbps connection. We run a youtube channel. I want to keep data in his pc and access it quickly. How can I do that. We don't live together so I can't use his hard drive physically. Is there a way to keep data in his pc and access it like it's in my pc? We live in same country in same city. 9km distance between if that helps. Thank you :)
Hi,
get a external hard drive and bike between your house and his.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Sadly that would probably be the fastest way.
However the next best thing and probably the easiest would be to work together through dropbox.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
As others already pointed out those internet speeds are horrible so don't expect the file transfer to be fast but you can try to use something like Syncthing. Alternatively any SVN could work too but it would be harder to set up... At least I still hadn't gotten around to setting up a SVN server yet (only used the client so far) while I basically became dependent on Syncthing. Additionally you could always try using a VPN and connecting to your friend's network but personally I'd prefer using Syncthing.
I want to keep my files in his computer and access it later. Dropbox is for sharing files right?
