Looks fantastic to me
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/528620-help-with-planned-build/#findComment-7014622
Hey guys I'm planning on building my new build:
http://pcpartpicker.com/p/DfBx4D
Will all of this work work or do I need to change anything? Any help would be appreciated thanks
i would only change cooler for a little bit more aesthetic but still its good build . Sorry that i cant recommend anything else than be quiet dark rock 3 cooler since thats the only one i am using for months and performance is not bad but  i wonder if my new CPU will hold it :P
CPU i5 6600k 4,4Ghz , COOLER Dark Rock 3 from BQ, RAM 16 GB of ddr 4 2800MHz from corsair,
 PSU EVGA 750 W GOLD G2, MOBO Msi z170A Gaming M3, CASE NZXT H440 Black/Blue,
GPU Geforce GTX 980 Gigabyte G1 Gaming,
STORAGE 1 SSD Samsung 850 Evo 250 GB and 1 HDD 500GB WD, Windows 8.1.
https://linustechtips.com/topic/528620-help-with-planned-build/#findComment-7014647
Looks good but A. Why do you need an optical drive and B, why do you need such a high-wattage PSU? 650W G2 would be enough already unless you plan to SLI and OC, then 850W would be good.
https://linustechtips.com/topic/528620-help-with-planned-build/#findComment-7014652
I would go for X99 build for that budget.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/528620-help-with-planned-build/#findComment-7014657
Scrap the 6700k and get a 5820k with a 280mm aio like a h110 or a x61.
Agreed, I would say the 5820k is better in almost every scenario.
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/528620-help-with-planned-build/#findComment-7014694
Tell us your budget, We'll make a nice build.
Also tell What are you going to use your PC for.
https://linustechtips.com/topic/528620-help-with-planned-build/#findComment-7014711
