Worth upgrading my audio?
Hi there,
Sorry if this is a bit of a rinse and repeate question.
I was wondering whether it was worth upgrading my audio, I'm currently using the audio off my z87x-d3h motherboard which if I'm not mistaken is a Realtek® ALC892.
One of the options I was looking at was a Fiio e10k. The headphones it will be paired with are the Audio-Technica ATH-AD900x's.
These will mostly be used for music listening (prog metal and similar) and gaming (CS:GO and SWTOR etc)
Look forward to any responses.
https://linustechtips.com/topic/527483-worth-upgrading-my-audio/
No. Stick with onboard
https://linustechtips.com/topic/527483-worth-upgrading-my-audio/#findComment-7000643
I have been using it for about 3 months, and just been wondering if I can get even more out of it
Your cans can be driven by a toaster.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
https://linustechtips.com/topic/527483-worth-upgrading-my-audio/#findComment-7001212
