So there is a little bit of an over hang of paste around the sides should I try and clean it up or leave it? Also how much paste should a put on the GPU about the same as a processor?
http://imgur.com/L30gGxt
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/527473-390x-re-pasting-help/
already got it taken apart? nice, that was quick. You could try and clean up a little, it wouldnt hurt, but since it is off to the side it shouldnt affect cooling. and yes you would want to put about the same as a processor, but maybe more of a thin line because of the rectangular shape. I have done that with positive results.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000518
Clean it off with a cotton swap that has a bit of iso on it. If you use a dry cotton swap the fibers will catch on the transistors. The reason i clean it off is because thermal paste is supposed to be a very thin later to bridge the cap from the GPU to the heatsink and help transfer the heat but when you have excess paste on the sides it can act as an insulator instead.
Also i would recommend spreading the thermal paste on the GPU rather than using the pea method. CPU's have heat spreaders on them so it's not as important but the GPU is just the bare die so it's important to cover the whole thing. Make sure it's a thing layer though.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000546
Too much? Or good? http://imgur.com/EOm5DUO
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000548
Also i would recommend spreading the thermal paste on the GPU rather than using the pea method. CPU's have heat spreaders on them so it'snot as important but the GPU is just the bare die so it's important to cover the whole thing. Make sure it's a thing layer though.
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000571
Looks like a tad too much. Get rid of the old crap on the sides and spread that thermal paste across the die. That's my recommendation.
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000609
Another problem with using the pea method on a GPU die is that if you use too little the corners of the die won't have paste on them when you apply the heat sink and if you use too much it will over-spill onto the transistors and it looks like you're using Arctic silver 5 which is conductive.
Just follow my original comment, I've re-pasted like 60 cards in the last couple years (refurbishing old graphics cards).
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000630
Let me know how it goes with temps and whatnot afterwards btw.
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000685
its a little thick in one spot, might want to remove some, but i dont think it will hurt anything.
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000738
It's the same.....no difference at all, maybe when pascal comes out I'll sell this so quick, last time I'll buy an amd card
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000781
although this card does do a lot better then the old one.. Because It wall actually drop the temperature it had and slowly warmer.. But I don't know if I'm not used to the noise because I had a 750ti for so long and I just don't understand how your temps are so good....
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7000786
It is not conductive.
@Matt_Twinkletoes I would suggest Gelid-GC Extreme over AS5 if you can. Much better.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7001234
It's your airflow. The MSI 390x isn't loud at all in stock settings. Your airflow is probably holding it back. With proper airflow it should be around 70c with 52% fan which is fairly quiet.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7001236
There shouldn't be much of a difference. The default paste was fine. I repasted mine but my temps still sucked so I removed the bottom card. Airflow solved it. It's a 250w+ tdp card.
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7001240
Ah you're right. I heard that it was and i guess it made sense to me since they claim it's a polysynthetic silver and real silver is extremely conductive. My advice was still good though based on what the company has to say about the paste.
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7001611
What is your current case and fan configuration?
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7001615
Seem like hot air accumulated inside your case. Did you try check the temp with side panel off?
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7003550
Sometimes side panel off doesn't help if beneath the card is obstructed.
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7003586
Should my case fans be pushing the cold air towards it or pulling air away from it? Because right now I have one fan blowing air towards the card. What gets the warmest on the card is the fins if you stop them
https://linustechtips.com/topic/527473-390x-re-pasting-help/#findComment-7004135
