Hi guys can anyone explain why my Gpu dont wanna thermal throttle? Its a geforce gtx 650m and since my fan died it thinks 80 degrees celsius is okay to have when watching 2 video´s at once and 93 when under load. I even have it on (broke) cooler so it does not strangle itself in my lap or blanket
https://linustechtips.com/topic/527320-gpu-does-not-thermal-throttle/
Why are you complaining about it not thermal throttling? I would take that as a blessing m8... forreal though fix the fan before you legs catches on fire.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
Is it not possible to just make it thermal throttle? I dont wanna spend the extra money on the fans and time to switch it out since im getting a desktop before the year ends.
Buy a notebook cooler, it's cheap and it will do the job.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
In MSI Afterburner there is a setting where you can turn on and off thermal throttling and set it to what degrees you want it to start thermal throttling. You might want to try using a case fan and zip tieing it to the heatsink of the GPU. It may look ghetto but it will perform better and that's what's important
cant find it, where is it?
can you reccomend any?
I'm currently on a 256K connection so I can't tell you exactly what, but really any cooler. I have a Hama and an Intex cooler and they do the job right
My rig:
HDD: Seagate 500GB
RAM: 1GB DDR3-800
HDD: HGST 320GB
