Power supply powerful enough?
Go to solution Solved by STRMfrmXMN,
Oh gotcha. Yeah that'll be fine.
Have a system with an A8-7600 in it, with a 400w power supply (Really only 20 Amps on the 12 volt rail).
Would putting an HD 6850 be too much for the power supply?
(I would get a new power supply if I had the money to do so.)
Any other ideas to up the systems gaming performance would be awesome.
Stock motherboard
8GB DDR3
500 GB SSHD
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/527209-power-supply-powerful-enough/
What is it?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Stock motherboard
8GB DDR3
500 GB SSHD
There's more to a PSU than the wattage it provides. What PSU is it?
What is it?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256097&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Think its fine, just wanted other people's opinions (I do ghetto builds all the time so this feels to easy. :P )
Stille (Desktop)
Evoo Gaming 15"
20A 12v = 240w on the 12v rail.
Stille (Desktop)
Evoo Gaming 15"
Thanks!
Stille (Desktop)
Evoo Gaming 15"
