Intel is usually more expensive, decent brand.
Samsung evo/pro are also decent choices and evo is cheaper (good quality) and pro is equal to intel's higher priced items (longer warranty and slight performance increase over evo).
Adata are cheapo ones that people use to set in raid, and I would NEVER touch Kingston ssd3now (or w/e that one is called). The xfury brand for ssd is also sub par.
Still new, but learning
i7 4790K / GTX 970 G1 Gaming / Maximus VII Hero / Swiftech H240x / Corsair Vengeance Pro 16gb, 1600mhz, cl9 / 850 evo 250GB /
WD Blue 1TB / HX850 / Phanteks Enthoo Pro
https://linustechtips.com/topic/527117-help-for-ssd/#findComment-6995970
you can get 950Pro for 300$ and it would be the fastest SSD as of yet
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/527117-help-for-ssd/#findComment-6995973
I have one of those Kingston SSds, why are they bad?
CPU: Intel Xeon E3 1231 V3 3.4ghz CPU COOLER: Cryorig H7 w/ Red Corsair SP120mm  MOBO: MSI SLI Krait Edition Z170 MEMORY: G.Skill Ripjaws 8gb (2x4) Storage: Kingston V300 120gb, WD 1TB GPU: MSI R9 390X CASE: Phantom 410 (ew) PSU: Thermaltake Toughpower Modular 550w CASE FANS: 4 CORSAIR SP120mm MONITOR: LG 25UM67 KEYBOARD: Das4 Ultimate Cherry MX Blue MOUSE: Deathadder Chroma Left-Handed AUDIO: Sennheiser HD598 Black, Astro A40s
https://linustechtips.com/topic/527117-help-for-ssd/#findComment-6995986
I haven't seen any Kingstons failing or under-performing so far personally. I wouldn't advice against them, but as others have said at this price point I think the 850 Evo is a great buy.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/527117-help-for-ssd/#findComment-6996003
They did a bait-and-switch with the NAND chips, switched to Asynchronous NAND instead of Synchronous NAND. Cut the speed of the drive clean in half. 140MB/s read, 70MB/s write. About as slow as a mechanical hard drive, possibly even slower. About on par with eMMC. Pathetic. And they're the only SSD that Staples sells to average consumers, so they don't know they're being screwed up the ass.
https://linustechtips.com/topic/527117-help-for-ssd/#findComment-6996010
As @Becausei'mBatman said, they released an initial one for benchmarks, then following after that they changed the manufacturing of the product to a different country and decreased costs of production. Due to this, the specific brand and model I mentioned is so sub par that it ranks equal or less than a base quality Adata. You may have lucked out on it, or have a different model, either way the ssd branch for Kingston is a tad sketchy.
Also, @ KemoKa explained it quite precisely. They don't fail, but they under perform and are horrible value. Hence why it is always on sale on Amazon and Newegg.
https://linustechtips.com/topic/527117-help-for-ssd/#findComment-6996014
