Corsair Air 240 CPU Cooling?
Solved by WoodenMarker,
hmmm you are right. i just looked up the dimensions of them, they are too tall. the noctua nh-u9s is 125mm (ive read that a 130mm cpu cooler can fit in the 240). is that able to achieve what i want for overclocking or is the h100i gtx the better option?
The H100i gtx would perform better but not worth the extra money imo--you might as well get an i7 instead with that money. The NH-U9S would fit and should be enough cooling.
Featured Topics
tinpanalley ·
Posted in Networking0 -
DoughmanX_HD ·
Posted in Windows1 -
220VoltsallCore ·
Posted in Operating Systems3 -
Ridoheru ·
Posted in Graphics Cards1 -
EpicAAron ·
Posted in General Discussion0 -
4
