Will a Hyper 212 evo fit in my system
MoonlightSylv
If not what cheap(ish) cooler will fit?
Specs in signature
✨PC Specs✨
AMD Ryzen 7 3800X | MSI MPG B550 Gaming Plus | 16GB Team T-Force 3400MHz | Zotac GTX 1080 AMP EXTREME
BeQuiet Dark Rock Pro 4 Samsung 850 EVO 250GB | NZXT 750W | Phanteks Eclipse P400A
Extras: ASUS Zephyrus G14 (2021) | OnePlus 7 Pro | Fully restored Robosapien V2, Omnibot 2000, Omnibot 5402
Not sure it would quite fit. Max height is meant to be 150mm for the case, it's meant to be 159-161mm for the cooler.
But why would you be using it on an i3?
Sig under construction.
Stock cooler.
Idk I like everything cool
✨PC Specs✨
The stock cooler is already more than enough to keep an i3 cool.
Yeah, the stock cooler should be more than enough. I've only just used the stock cooler for the first time with my i5 6500 skylake build..... Even at 100% load it barely creeps above 50 degrees, and stays closer to the lower 40's when gaming. I am actually pleasantly surprised how well it works.
CPU: i5 6500 | GPU: GTX 960 SSC | MOBO: Asus Z170m-Plus | RAM: 16GB DDR4 G.Skill | Case: Fractal Designs Node 804 | PSU: EVGA 750w
Only reason to get aftermarket cooler for i3 is noise. Your CPU isn't going to see much over 60C temps ever.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
