Hello everyone.   recently I got GTA V from gmt-max.org repack  I need to know where the save game file is so I can transfer it to a different PC.  if someone could tell me the location in file explorer it would be greatly appreciated!   I already tried      C:\Users\%USERNAME%\Documents\Rockstar Games\GTA V\Profiles      and it is not there    please help  thanks
https://linustechtips.com/topic/526123-gta-v-pc-problems/
We can not discuss about something obtained illegally.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/526123-gta-v-pc-problems/#findComment-6983055
You save files will be sync'd through Steam (if you purchased a steam key), or through Rockstar's online service so if you simply log into your account on the other PC, everything will sync.
If you illegally obtained the game, then we can't discuss that here and I wish you the best of luck with your search.
https://linustechtips.com/topic/526123-gta-v-pc-problems/#findComment-6983077
it is a torrent and i now see that i can't  talk about that here   i appreciate it anyway guys  thanks :)
https://linustechtips.com/topic/526123-gta-v-pc-problems/#findComment-6983126
You can check the Steam Community for the location of save files over at the link provided.
Although of course, this will only apply to the Steam or SocialClub version of them game.
Otherwise, I suggest you email RockStar Support and ask them about the game you acquired from the gmt-max.org site.
I'm sure they'd be more than willing to look into your situation, if you provide them with your home address, name, an phone number. :)
They might even send some men in dark colored suits to your house to retrieve your computer for further analysis.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/526123-gta-v-pc-problems/#findComment-6983141
get it legally.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/526123-gta-v-pc-problems/#findComment-6983157
just buy the game.. saves you all these troubles
https://linustechtips.com/topic/526123-gta-v-pc-problems/#findComment-6983158
:P
https://linustechtips.com/topic/526123-gta-v-pc-problems/#findComment-6983225
