Need help deciding Ethernet or Fiber for exterior run
Solved by W-L,
The AP in question actually has an SFP port available, as does the switch I would connect to. All costs including the SFPs for Fiber or the Surge Protectors and grounding hardware for Ethernet have been included.
For surge protection unless your running out and tapping into another building or your place is a duplex it would be good to have surge protection but not 100% needed. Most times Ethernet surge protectors are used for aerials or exterior AP's which can potentially get struck by lighting. For underground and I assume running along the house an exterior grade cable that is sealed/potted with gel and extra insulation is all that is needed if your going for direct burial, however having it in a conduit is always a plus.
