So I have a Razer Anansi, and my puppy decided he wanted to chew on the cord >.>
Anyway I want to replace the keyboard with a mechanical keyboard but I don't know what keyboard to get.
I like the 5 macro buttons on the left side, so I was hoping to find one like that.
I want either red or brown switches, and was trying to get away from Razer because that's all I've used.
Any help would be awesome :)
https://linustechtips.com/topic/52572-help-with-keyboards/
G710+?
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-704240
G710+?
Agreed.
The Logitech G710+ is a highly regarded keyboard. Solid build quality, MX Brown switches, decent number of macro buttons. :)
"Be excellent to each other" - Bill and Ted
Community Standards | Guides & Tutorials | Members of Staff
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-704248
CM storm trigger and logitech G710+ would be your best options.
Fractal Design Define S, i7 3770K @ 4.5GHz, Noctua NH-D14, Asus Sabertooth Z77, EVGA 980Ti SC+, 4x8GB Corsair Vengence 1600MHz, EVGA P2 1000W, Creative sound blaster Z, 2xSamsung 850 120GB RAID 0, 2xWestern Digital Caviar Black 1TB Other stuffs: BenQ XL2411t, LG Flatron M2262D, Ducky Shine 3, Logitech G400s, Steelseries QCK Heavy, Beyerdynamic DT770 pro 80ohm, Shure SE215, Blue Snowball
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-704316
Agreed, the Storm Trigger has 5 macro keys on the left, is backlit, comes in various switch types.....the G710+ is great, but limited to Brown switch only.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-705564
Where would be the best place to get the CM storm trigger? I could only find it on amazon
It'd be hard to recommend any online links w/o know where you are from. Can you source from the US? Or, Europe?
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-705706
US
Here's a Storm Trigger Red from newegg at <100USD including shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16823129010
A Logitech G710+ (only Brown) @ 130USD
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126299
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-705868
I personally like the G710+ more because their gaming software is better than the Coolermaster one imo.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-705892
I  second this. I have a CMStorm Trigger, and its a great keyboard, but the software is very confusing to use. It would also come down to if you like O-rings under your keycaps or not as the G710+ has them.
Rig specs: 3930k | 32GB RAM | GTX580 | Asus PB278 | Corsair K90 | Logitech G700 | HD558's
https://linustechtips.com/topic/52572-help-with-keyboards/#findComment-705959
