Refurbished Hard drive?
Is it worth it? I want to know if the horror stories are true. Also does cache for a hard drive a really matter?
You can't tell what it's been through with its last owner.
It's a bad idea - you might get lucky, but they generally aren't that much less expensive than new drives.
 Almost as cool as my temps
https://linustechtips.com/topic/525475-refurbished-hard-drive/#findComment-6974616
NO don't get a refurbished hard drive. there is not really that much of a point, new hard drives aren't that much.
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/525475-refurbished-hard-drive/#findComment-6974621
