Whats a better overclock for my 980Ti?
Remixt
So I got my core to 1504 MHZ boost, but if I increase my memory by anything more than 40 3dmark will crash halfway through.
When I lower that to 1450 MHZ I can get my memory up to +290 without crashing. Is it better to take the 50 MHZ hit or just keep the core at a higher speed.
CPU: Ryzen 5950X Ram: Corsair Vengeance 32GB DDR4 3600 CL14 | Graphics: GIGABYTE GAMING OC RTX 3090 |  Mobo: GIGABYTE B550 AORUS MASTER | Storage: SEAGATE FIRECUDA 520 2TB PSU: Be Quiet! Dark Power Pro 12 - 1500W | Monitor: Acer Predator XB271HU & LG C1
Core. Memory is not really a bottleneck at the speeds we currently have available.
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
since you're running 3d mark you can look at the graphics score and see what's better the core or the memory
usually the core is better up to a certaint point
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
Try upping your voltage as that can help the memory controller as it has for me.
Best Bench Runs & 24/7 Rig
Best Bench Runs
i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T
24/7 Rig & Clocks
i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda
Try running valley or 3dmark and see what yields the best results
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
Its up as high as it will go already and my temps are really high already so I don't think thats a good idea.
In that case, sacrifice one.
Best Bench Runs
24/7 Rig & Clocks
