So I recently got The Logitech z506 speakers and when I plug my headphones into the port that is on one of the speakers, no sound goes through my headphones at all, I tried looking on google for a solution but didnt find one. If you could help that would be awesome!
https://linustechtips.com/topic/524947-logitech-z506-problem/
Is there anything like lint stuck in the port?
Also is the headphone jack seated properly?
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/524947-logitech-z506-problem/#findComment-6968126
Assuming sound is coming out of your speakers when you plug in the headphones, it's probably malfunctioning.  It's best not to use it anyway if you can help it.  The sound  that came from the headphone jack of my old Logitech 2.1 THX speakers was horrible, and it takes exactly as much electricity to run the headphones as it does to power the speakers (maybe a bit less since the subwoofer might be in standby, but wasteful nonetheless).
https://linustechtips.com/topic/524947-logitech-z506-problem/#findComment-6971140
