Will this build (mostly cpu cooler) work for a few months until I can get the water cooling figured out?
Also should I just figure out fans for water cooling now or purchase a few cheap ones and not worry about noise?
Any other advice on build is welcome.
Build is going to be used for dev/gaming in a virtualization env. GPU passthrough is why amd card.  External storage, monitors, mouse,keyboard are already in place.
Thanks
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor  ($554.99 @ SuperBiiz)
Motherboard: Asus X99-DELUXE/U3.1 ATX LGA2011-3 Motherboard  ($388.99 @ SuperBiiz)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($379.99 @ Micro Center)
Total: $2175.68
Generated by PCPartPicker 2016-01-10 21:37 EST-0500
EDIT: New build with suggested cpu changes. I also added another gpu now vs later.
So should I still think about a different PSU knowing that once I get a water cooling setup in place I will be doing a bit of overclocking?
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ SuperBiiz)
Video Card: MSI Radeon R9 390X 8GB Video Card (2-Way CrossFire)  ($379.99 @ Micro Center)
Total: $2375.67
Generated by PCPartPicker 2016-01-11 11:18 EST-0500
https://linustechtips.com/topic/524934-build-cooling-help/
I'd grab a cheaper 5820K and X61 Kraken AIO liquid cooler. Change out the PSU for a cheaper one, the 1000W one is overkill for just one 390X.
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($117.99 @ SuperBiiz)
Total: $2054.78
Generated by PCPartPicker 2016-01-10 21:44 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/524934-build-cooling-help/#findComment-6967997
Yea, there is absolutely no reason to buy a 5930k (even if you actually needed the pcie lanes, a plx motherboard + 5820k is generally cheaper than a 5930k with a regular/mid range motherboard). Please don't.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/524934-build-cooling-help/#findComment-6968026
It's fine, but do you really need the extra PCI-e lanes from the 5930k? If you aren't overclocking the Hyper 212 is fine
Maybe get the Power Color Devil Hybrid 390X, it's the best 390X available
https://pcpartpicker.com/part/powercolor-video-card-axr9390x8gbd5adhe
and the power supply is a bit overkill, maybe look for an 850W unless you're going to add more GPUs, no idea how crossfire virtualization is going to work out though
And the HAF XB Evo is about the most functional case around, and actually if you get the HAF XB EVO what you can do is mount the GPU radiator in the back of the case, a 240mm Radiator onto the front of the case, and then a 200mm low RPM quiet fan for the intake on the top, cooling is also going to be pretty direct in that case, no pun intended
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265
https://linustechtips.com/topic/524934-build-cooling-help/#findComment-6968036
Yeah agree with others, a 5820k will be much better for you. You could use the extra money to get an aio like the kraken x61 (as HKZeroFive said).
Also agree with Streetguru, the PowerColor Devil is a great 390x card.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/524934-build-cooling-help/#findComment-6968125
Stick with the board I have then just with other chip or get a different board?
https://linustechtips.com/topic/524934-build-cooling-help/#findComment-6968300
I'm going to do a custom wc loop once I decide on components. Only then would I be overclocking.  I will probably be adding another 390 also at some point.
https://linustechtips.com/topic/524934-build-cooling-help/#findComment-6968340
Are you crossfire is going to work under virtualization? or are you going to do like 2 virtual machines with a GPU each?
Overclocking a workstation generally isn't advisable, as you want it as stable as possible
There is a Triple Slot Dual 390 GPU out that's pretty good for the money if you can find it now
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131680
Maybe up your PSU to a 1200W in that case, this one seems to have some decent reviews, it gives you plenty of headroom for 2 390s or 390x GPUs, not sure if there's a better 1200W that one just had some decent reviews, a one JonnyGuru reviewed the 1000W version and recommended it, he's like the power supply guy basically
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=435
https://pcpartpicker.com/part/rosewill-power-supply-quark1200
https://linustechtips.com/topic/524934-build-cooling-help/#findComment-6968481
