I have an EVGA 750 B2 power supply and the fan is by far the loudest thing in my computer. According to the EVGA website it uses a 140mm fan so I am thinking about switching it out with the Noctua NF-P14s redux 90 but I was wondering if that fan is powerful enough for a power supply. Is it?
Space is pretty awesome.
https://linustechtips.com/topic/524863-psu-fan-replacement/
It's a lot harder than what you think. Usually they're custom designed fans. Linus stated going through a power supplies internals is very dangerous and could possibly kill you. I have a 500B and I don't hear any noise from it. Just RMA it or something.
https://linustechtips.com/topic/524863-psu-fan-replacement/#findComment-6967075
I doubt it is louder than its supposed to be. When compared to my computer which only has NF-F12s with LNAs it is loud.
https://linustechtips.com/topic/524863-psu-fan-replacement/#findComment-6967147
it is a pain in the ass to replace a fan on a psu. plus you need to know how to safely discharge the capacitors if you dont it could easily result in death. dont mess with a psu unless your skilled and have experience with it.
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/524863-psu-fan-replacement/#findComment-6967179
Ideally the more pressure oriented the fan the better inside a PSU, something like the NF-A14 are a better option. Most also use a two pin system so you will require an adapter like this below:
http://www.moddiy.com/products/3%252dPin-Standard-Fan-Connector-%28Male%29-to-Mini-2%252dPin-GPU-Fan-Connector-%28Female%29.html
http://noctua.at/en/products/fan/nf-a14-pwm.html
note the regular safety stuff when opening a PSU, to unplug it and cycle the power a few times by pressing the case's power button and letting it sit for at least 30-60 mins before opening. When open be aware of the contacts of the capacitors and to not short them while working.
https://linustechtips.com/topic/524863-psu-fan-replacement/#findComment-6967395
I actually have a spare NF-14 lying around, I'll use that. Thank you and I'll look into proper care and how to safely discharge the capacitors before thinking about opening the psu.
https://linustechtips.com/topic/524863-psu-fan-replacement/#findComment-6967941
