do what you think is best...
Not the best practice but...
(This is someone else's PC; you don't want to be part of the liability)
What is the motherboard in question?
According to the NZXT 410 Tempest user manual, there should be nine motherboard stand-offs included withe a computer case, though with more recent motherboards, ATX form factor motherboards may have that many stand-off mounting points.
NZXT Tempest 410 manual: http://nzxt.jp/downloads/manuals/manual_tempest_410elite_multi.pdf
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/524790-need-help/#findComment-6966414
An evga z97
EVGA Z97 Classified, or FTW?
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/524790-need-help/#findComment-6966479
I asked for more but they only gave me one standoff, idk what to do. I've asked and people told me to buy any standoffs but people told me that I have to get the one adequate for my motherboard
https://linustechtips.com/topic/524790-need-help/#findComment-6966480
Classified
From what I can see, the EVGA Z97 Classified has 10 stand-off mounting points, and your motherboard should have enough mounting points for all 10.
Yes, the size of the motherboard stand-offs CAN vary between each computer case manufacturer, BUT the common standard these days is M3 #6-32 x 4mm (4mm thread length). M3 #6-32 will always be it, its the length that can vary (i.e. 4mm, 6mm, 8mm, etc).
BUT if you want to be 100% sure, it is best to measure the stand-offs you currently have, and go to the local PC store, or look for the proper ones online.
Better yet, bring a stand-off in with you and ask the local PC shop, "I want to buy more of THIS."
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/524790-need-help/#findComment-6966609
mine is 4mm
https://linustechtips.com/topic/524790-need-help/#findComment-6966667
I need 4 more standoffs, idk if I should install it now
It is up to you.
4mm. Bam. Good.
But...where do you live (US? Europe? etc)?
Any preferred local stores or online retailers?
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/524790-need-help/#findComment-6966690
It is up to you.
4mm. Bam. Good.
US, newegg, and yes I have a store near me. I don't want to leave the components laying around but then again I don't want them broken lmao
https://linustechtips.com/topic/524790-need-help/#findComment-6966720
If you have a Microcenter near-by (double check with the guys who work there, or bring one stand-off with you...like like 4mm in the pictures)
$2.99 for a pack of 15: http://www.microcenter.com/product/218738/Brass_Spacer_6-32
NewEgg...black colour set of screws (thread count is definitely 4mm; I dug out some of my extra stand-offs to measure and compare with :) )
$6.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16811998139&cm_re=motherboard_stand_off-_-11-998-139-_-Product
Fry's also seems to have a few kits, but best to actually go into the store to look.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/524790-need-help/#findComment-6966838
