Hi,
I'm looking for some good recommendations for Red coolant, it's needs to be available in the UK. I have heard bad stuff about EK's Red Coolant but if you have experience please let me know if it is bad. The others I have seen are Mayhems X1 Red coolant and Aqua Computer Red Coolant and also XSPC Red coolant.
Any recommendations guys?
Custom PC:
Intel Core i7 5960X GTX1080 Strix | 64gb 2400mhz DDR4 Corsair Vengeance Ram | Samsung S951 256gb M.2 | 4TB WD Blue SSHD | EVGA Supernova G2 1300watt PSU | Acer XB270HU | Corsair K95 RGB | Corsair M65 RGB |
https://linustechtips.com/topic/524770-recommendations-for-red-coolant/
Mayhems
They make the best coolants/dyes
Mayhems
I have had previous experience with their coolant I was using their pastel yellow up until 4 weeks ago but jayz video changed my mind about it and I got it out of my loop before it clogged anything. But I hear the X1 is a less maintenance.
Custom PC:
why would it clog anything?
the only thing i remember was that it changed colour because of some component in one of his loops that reacted with it
there are thousands of people who have been using mayhems coolants for years and they are perfectly happy
and yes the X1 is even better
He said he was concerned about his GPU blocks being clogged but in a later video he opened up one of the GPU blocks and it was perfectly clear the reason his gpu was getting quite hot was because of something else but I didn't want mine to go brown so I decided to change it before it got to that stage as mine did darken slightly.
Custom PC:
There are also a shit load of people coming out with issues in their pastel line.
But that said, the mayhem dyes are the best overall and there is little indication that outside of pastels you need to worry about more than the standard dying of your parts.
@OP I'd personally recommend red tubing instead of coolant because you will get the same effect without needing to clean the shit out of everything you own when you change colors. And tubing is cheap.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
