so every like 3-4 days I reach 98-99% of my 16gb of ram usage. with like chrome tabs and illustrator on. and a few other things.
and the ram gradualy fills up as I use the pc over the 3-4 days..
so how do I fix this ?
https://linustechtips.com/topic/524681-how-do-i-fix-memory-leak/
Find what is leaking?
Works with every leak.
https://linustechtips.com/topic/524681-how-do-i-fix-memory-leak/#findComment-6964769
how does one do that ? and how do I fix it then ?
https://linustechtips.com/topic/524681-how-do-i-fix-memory-leak/#findComment-6964779
Uhm. Open task manager and look what the fuck is using all the RAM?
https://linustechtips.com/topic/524681-how-do-i-fix-memory-leak/#findComment-6964782
I think I know what is :
post-85015-0-49651300-1452456579_thumb.p
I have 22 chrome tabs opened
4 of witch are the forum
https://linustechtips.com/topic/524681-how-do-i-fix-memory-leak/#findComment-6964829
After Rebooting your PC, Right click on start button > click "Command Prompt (Administrator)" > type "sfc /scannow" without the quotation marks and press enter > wait for it to finish and reboot.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/524681-how-do-i-fix-memory-leak/#findComment-6964836
