Hey guys,
after having trouble upgrading a prebuild system (http://linustechtips.com/main/topic/523046-pc-freezes-as-bios-startup-screen-with-a-new-gpu/) my friend decided upgrade the rest too.
What we'll take from the old one is a 1 TB HDD + OS, 6GB DDR3 RAM and the ODD. Already purchased is a MSI GTX 950 OC and a bequiet! System Power 8 400W. Because it's a budget build, we want to keep both components.
What my friend wants:
- silent operation (most important point)
- at least 2 USB 2.0 and 2 USB 3.0 at the case front, at the back at least 6 USB ports
- obviously as much power as it can
- black case, sth like the bitfenix shinobi style (he actually picked it, but if there's another case that's that style and has more to offer, suggest it)
- 3.5" card reader
Aim:
Playing games like the GTA series (from GTA III to V), simulators, cities skylines, age of empires, ... smoothly, but no need for ultra settings at 1920 by 1080.
Budget:
300-400€ (if it's really worth it, he could give another 50 bucks) (in Germany, buying from here: mindfactory.de
what i got so far:
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/67c5762210c062305bfdbac33110c70c0327b429d1ca826adb3
that's basically over the limit. I would cheap out on one extra case fan (the case actually comes without fans) and the tower cooler.
Is it ok to go with the i3 4160? I picked the i5 because of the simulators which are more cpu heavy than gpu, also gta v is cpu intensive.
Thanks in advance!!
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/523875-pls-help-complete-the-build/
For playing GTAV, you really need the cores but if you can't fit it into the budget, go with a newish AMD with no integrated graphics. Also, you already have 1TB of storage, so If you ditch the 2TB blue in the parts list, you could buy it later, when he needs the storage. I play lots of games and I have less than 500GB of files and if you uninstall all the games you don't use, then 1TB is fine for everything.
the 2 TB is in there because he does a lot of photographing in raw format so.... but that's true, buying later will be also possible
- Ryzen Build -
2x Dell UP2516D
which amd would you suggest?
sry for answering in two posts
- Ryzen Build -
2x Dell UP2516D
i3 4160 won't run gta V, and is really bad for gaming in general because it's a duel core. You nee the i5 quad core.
No no no no no no no.
My A6-3650, is 4 years old. It is equal to an i3-550, yes first Gen i3. I play GTA V high settings 40FPS. The i3 is dual core hyper threaded. Look at the i3-6100 vs a stock i5-6600k. With 2666mhz RAM and the i3-6100 OCd to 4.4Ghz, the i3 beats the stock 6600k in Far Cry 4 and Shadow of Mordor
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
-snip-
First of all, when you're on such a small bugdet, you shouldn't be picky about stuff like number of USBs or case. Get the cheapest case possible. You can always replace that later, or add an USB hub if you need.
Second: You don't need that 2TB HDD. Nor that tower cooler - you're getting a locked i5, stock will be just fine for that.
Voila, you're within budget now, even with the case.
Stick with the 4160, or see if you can fit in a MSI Z170 PC MATE, a i3-6100 and 2x4 2400-2666mhz RAM, you can then over lock using BCLK to get to 4.2-4.4GHz. Ass I said before, sometimes this method can beat an i5-6600k at stock clocks in games like Far Cry 4 or Shadow of Mordor
Hey guys,
- 3.5" card reader
Aim:
Budget:
what i got so far:
Thanks in advance!!
I wouldn't get that hdd . The WD blue's over 1 TB are 5400rpm , which is terrible , especially as a boot drive.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
