Highest temp for safe FX9590
Go to solution Solved by vagabond139,
so during idle, it jumps between ~16c to around ~55c.
When on load, using prime 95, smal ffts, is a WAT
hold up
its a negative numer :/
~0.6c
it crashed :/
Well its time for a cpu cooler upgrade, the FX 9590 is a mental cpu when it comes to heat, or you could just keep the current cpu cooler if you don't put it under full load like that normally. Or you could strap a Delta fan to it if you are a deaf.
Prime95 is not good for CPUs, I suggest using a different stressing tool like Cinebench. But 78C in Prime95 is not too bad.
cpu seems to be passing everything in prime. Just short 15 mins and itl be running one hour no issues
passed cinebech no problems
cpu seems to be passing everything in prime. Just short 5 mins and itl be running one hour no issues
Yes but Prime95 makes your CPU hotter than anything you'll ever do so 78C is a worst case scenario which isn't too bad.
especially if its almost 50 mins straight
Still 78 with fans? Now I know why amd chips are famous for heat
while running prime for almost the past hour. And its also not liquid cooling, which is recomended
My top 390x card gets to 100c when folding or something, dont remember, but 100C is the max
Could be better, but it's alright.
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
Could be ~15° cooler.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
