I´m planning to build an Lian Li PC-08ish Case by myself.
I have CNC and a laser cutter (I made robocup robots)
I never did something like this so please share your experience on the topic like or example:
What Aluminium to use and specific possible mistakes I should avoid.
https://linustechtips.com/topic/522656-custom-case-from-scratch/
Only related thing I have done is use a laser cutter to make an acrylic midplate, so this is way over my league, but I would assumed you would want to minimize the amount of welds to do (so make like a big net to fold out)
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-6940804
this (and its prequels, in a design kind of way) has a lot of small tips and tricks.
aside from that, its like any other project you've worked on, measure, measure again and make sure you're correct to the millimeter (ideally, half or tenth of a millimeter)
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-6940818
-snip-
I would do some extensive reading on sheet metal engineering. I would not recommend welds but riveted joints. Also make sure to analyze how much load you want to put into your case and what the distribution is, this will guide your material selection.
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-6943028
Why is welding a bad idea?
Welding tends to distort thinner metals and can cause them to cup or bend very easily if not done properly causing tolerances to be off since it requires fairly precision work. I would recommend to start with a case and build from there like an IO plate:
http://www.mountainmods.com/motherboard-parts-c-21_34_66.html
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-6965930
Don't forget the little holes in the motherboard tray that the ends of the expansion card brackets slot into. That is all.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-6966757
Or avoid having to cut those slots by using tall (>=.5-inch) standoffs.
That's actually not a bad plan.
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-6973946
From personal experience, I can tell you that achieving a consistent, high quality finish is very hard to achieve. For starter tools, you at least need:
A bending or press brake
Drill and tap sets
Punch and die sets
Riveting equipment (if you want to go with rivets)
Drill press
Painting/Coating equipment
CNC/Laser/Precision Plasma Cutter (or a jig saw, but not nearly as nice looking in the end)
And a general skill with hands on work. I'm pretty good at that stuff, but it's extremely important (and probably the most important) to have the proper tools. Without them you're going to be scratching your head on how to achieve what you want with limited tools, and you'll have to take shortcuts and you won't end up with what you wanted in the first place.
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-6985425
Drill and tap sets
Punch and die sets
Drill press
Where could I get access to a bending or press brake and powder coating equipment?
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-7022405
In most places you would need to know someone who own a metal fab or workshop. If your in school and have a shop class most may let you work on some side projects or things using their equipment.
Powder Coating or things like metal plating will need to be contracted out to places that can do work like that.
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-7022464
You can get cheap bending brakes at Harbor Freight, or you can get multi thousand dollar hydraulic press brakes. As for powder coating, it all depends. You'd need an oven, special spray guns, a compressor, etc.
https://linustechtips.com/topic/522656-custom-case-from-scratch/#findComment-7022528
