Help with watercooling GPUs
Well for starters you'll need
1) A pump (D5 or DDC. I'd go D5 if you can afford the room)
2) Fittings (This one component will surely send your budget through the roof if you go and get a bunch of them, mix and match)
3) Radiators (Go for the biggest radiator you can fit into your case. Length first, thickness last)
4) Tubing (You can either go for soft tubing, acrylic/PETG, or even copper). Be sure that whatever fittings you're getting can fit the tubing.
5) Coolant (There are all kinds of coolant you can use to watercool, I personally prefer a premixed coolant from a reputable brand such as EK, PrimoChill, or Mayhems. Colors are personal choice, so I'll leave that to you)
6) Reservoir (Either a tube or a 5.25" reservoir will do. You can even set up dual loops for more badassery, though that doesn't increase cooling performance. I prefer tube reservoirs over 5.25" ones)
